hey mate,
try using different grades of sand paper.obviously rough to fine.and depends on what you are thinking about polishing.maybe you need to use something like a dremel to get into all those really tough areas.then when you get through the papers(the finer then obviously the easier the polishing will be) then if its fine enough you may be able to get away with a metal polish like the one that comes in the tooth paste tube or more abrasive,gumption.if you have to use a electric motor with a jewellers buff wheel on it ,it can become dangerous if you are not experienced and its extremely hard to use on big things.
tell me what you are thinking of polishing!!
