Results 1 to 4 of 4
Thread: How to remove box wax from carpet
    Jan 2014
    I had some boxes coated with a heavy wax on the carpet in the boot. After taking the boxes out, a whitish wax residue remains. The carpet had been treated with a water repellant some weeks prior to the boxes going into the boot.
    Advice on how to remove this wax would be appreciated. Thanks.
    Mar 2015
    NSW
    Try putting a kitchen paper towel on them and using a heat gun or hair dryer to melt the wax and soak it into the paper
    Jan 2014
    You're a genius! It works but I recommend covering the carpet and boxes in something eg an old sheet to avoid the problem.
    The wax did not melt till over 55C so it was not pleasant work. The first step was to cover an area with the kitchen paper then use directed heat to a patch and roll with a small roller eg dowel or chrome pipe a number of times. Finally heat the carpet and scrub with the paper. Discard papers frequently.
    Incidentally, the carpet was sprayed with 301 high tech fabric water repellant ( bought from car care, Ashfield.
    Pacific Paradise QLD
    An iron on low heat and some thick brown wrapping paper does the the job perfectly.
    Wasted your money on carpet treatment. Never works properly Had a whole house done once. Think it attracted spills rather than stopped them
