apply some more glass onto side and front edges to stiffen up even more!!
after finished glassing let resin set, then grind and sand back till smooth.
then to keep it OEM, drill some more holes
next step is to apply the fabric.....
i found out the OEM fabric is black front runner and some felty sort-of carpet stuff,
which i bought from Australian Trim Supply in Dandenong.
what you also need is some Kwik Grip Gel (from bunnings). not normal Kwik Grip as it will seap through the fabric
firstly cut your fabric roughly to size (leave a fair bit extra) and smear a thin layer of the gel all over the fabric and on the parcel shelf,
wait until the glue has gone off (not sticky) and then start applying fabric, starting from front and working to the rear.
do the same with the underneath side.
join both the carpets together, let it dry a bit to stick better. then trim all edges until looks how you want it.
And Voila, a new parcel shelf!!!!
i probably missed a few things so just ask
