Results 1 to 10 of 12
Thread: How to Fix VW Alloy Wheels (Golf Mk6)
    Jul 2009
    CREDITS
    First of all, I read this excellent write up & full credit goes to this fine individual.
    BMWTips wheel-scuff repair
    I’m posting this as a useful “how to guide” to give back to the VW community & anyone else out there who is frustrated that they’ve kerbed their alloys.
    TIPS
    Read the BMW tips carefully. Definitely do this on a hot summer day. Check the weather forecast to ensure there's no late rain/cool change. That can ruin the finish.
    Drying times are so quick and the faster curing allows for a stronger, lasting finish in hot weather. Slow drying times can cause problems and a lumpy / damage prone finish.
    I am an IT manager by trade and not a handyman by any means. I can fix taps, change an oil leak and install a light fitting... But i classify myself as an amateur. So this shows how straight forawrdish this type of project can be.
    As BMW tips said... Clean clean.... And lots of patience.
    EQUIPMENT
    Please ensure you have all these before your start your project. Or you will be like me & waste time driving around on a spare tyre. Australian prices as at 2013 shown
    Consumables:
    1. Wheel cleaner $8
    2. Putty $12
    3. Primer paint $17
    4. Silver BMW Paint code 354 (more on this in a moment) $29
    5. Clear Coat $17
    6. Sandpaper: 180 grit ($1.75). I also had 320 grit ($1.75) and 60 grit ($1.75) for the really lumpy dings.
    I have posted a separate pic so you can see what these look like.
    Tools:
    1. Masking tape
    2. Putty knife (I used a non-serated plastic knife)
    3. P1 dust mask or better
    4. Goggles
    5. Old newspaper
    6. Old rags
    This looks like a scary list. The other guy didn’t quite list all these – so please don’t feel overwhelmed. I just want you to be prepared and not waste time while you’re waiting for things to cure.
    PAINT
    A few forums mentioned using Wurth paint. Another mentioned BMW Paint Code 354. Admittedly the lack of retail availability of Wurth paint was the reason I kept procrastinating.
    So I bit the bullet and went to SuperCheap Auto. There I learned that Autobarn can mix aerosol paints!! I asked for BMW Paint Code 354 and they mixed it for me in 5 mins including gassing the can. Good news for us Aussie veedubbers. Good value for only $29.
    Is it worth getting Wurth? i suspect the metallic "grain" or flecks will be closer to VW spec than the paint I used. I feel the colour from Autobarn was right but the grain a touch too coarse.
    STEPS
    Here are the steps without the pics. Scroll down to see the pics & commentary.
    Step 1: Clean the wheels. This is where the wheel cleaner comes in. I used Armorall Wheel Cleaner.
    Step 2: Use putty knife and trowel on the putty perpendicular to the scratch. Leave the wheel on the car for now.
    Step 3: Sand down putty. Use a cork sanding block if possible. Again, do this with the wheel on the car.
    Step 4: Remove the wheel from the vehicle. The BMWtips guy said to cover the vehicle in case of loose spray... I say remove the wheel & continue the project in another location. Position the wheel so the work area is at the bottom.
    Step 5: Mask all exposed areas of the wheel and use newspaper to cover items such as valve, VW emblem, tyre.
    Step 6: Spray on primer. This is iterative & you may need to sand again if you find defects not seen in the original sanding.
    Step 7: Spray on paint. I recommend overspraying a little to blend in with the rest of the wheel. Even the pros do this.
    Step 8: Spray on clear coat. I recommend overspraying just so that you seal in all exposed paint.
    STEPS WITH PICS
    This is the scratch I am going to repair on my project.
    When you sand down the putty, a lot of dust is generated that goes everywhere. As BMWtips says, constantly wipe down the area. This will become important later on when it comes to spray time
    This is how the putty looks like
    This is the putty applied to the wheel
    Do all of the puttying while the wheel is still on the vehicle.
    Step 3: Sand down putty. Use a cork sanding block if possible. Also sand perpendicular to the scratch
    This is the end result
    Do all of the sanding while the wheel is still on the vehicle.
    Step 5: Mask all exposed areas and use newspaper
    Use masking tape and newspaper to cover items such as valve, VW emblem, tyre.
    Tip: put the affected areas on the bottom so that after you have sanded, there is less cleaning (since the grit falls downwards).
    You can see at this point i have done a lot more sanding with the fine grit and it is smoother. Hoever, i was to discover after applying the primer that it wasnt quite as smooth as one would like.
    While you're waiting for the primer to dry, update vwwatercooled.
    In this photo, the right most spoke under the newspaper has a defect.... use the fine grit to sand down, then respray the primer. Patience here is a virtue. Repeat as much as your patience will allow :p
    This is the result after sanding again with the fine grit.
    After respraying the primer, the patience has paid off and it's smoother.
    So I found that taking photos of the job was useful. This is after 2 sprays. I couldn't actually recall where the damage was !
    So I've had a bit of a side-track. That defect on the right most spoke wasn't gone after all. When I sprayed the silver it actually showed up again! So I sanded it all back and have re-applied it.
    Good news... success!!! This is more like it.
    Now just need to wait for it to cure, then onto the clear coat. Unfortunately the weather has become cooler, so drying times are extended and the paint layers don't feel as "stuck".
    Sorry for the dodgy pic, but the weather took a turn for the worse and thunder clouds rolled in. I will see if I can get a better photo in the coming days of the finished product, but it looked decent to me and a darn sight better than the gutter rash everywhere!
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
    Jul 2009
    First Project
    This was my first alloy project. Total time took 2.5 hrs. That includes cleaning the wheel, removing the tyre etc.
    The short duration was greatly facilitated by the hot 30 degree summer weather.
    Step 1: Putty
    Step 2: Sand down
    Step 3: Primer
    Step 4: Spray on paint
    Step 5: Spray on clear coat. Here's the finished product this morning after curing overnight
    Skoda Octavia Mk3
    Interested in your outcome here.. although with a machined finish there is no paint to cover up my (luckily minor) gutter rash on one wheel.
    re: embed, on the photobucket page on the right there is an "img" code.. click and paste and voila.
    Update: great result, looks waaaaay better than the before.
    Last edited by Dutch77; 12-02-2013 at 06:49 AM. Reason: delete embed pic to clean up thread, update for the result
    Jul 2009
    Thanks! I'll upload my first project which is kinda reasonable
    Skoda Octavia Mk3
    Jul 2009
    Here are the products I used for the job.
    Skoda Octavia Mk3
    Apr 2008
    Well done - very nice write up.
    I am looking to do same in the future.
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Apr 2010
    Thanks for posting cktsi,
    I used this and the BMWTips guide to refinish one of the wheels on my MK5 GTI. I wasn't too sure how I would go but I gave it a crack and I am very pleased with the result.
    The wheel I used only had some small gutter rash and some fine scratches. I ended up respraying the whole wheel and it looks perfect, just like the others.
    I used a couple of variations on your method though.
    - I used a big halogen light over the wheel in between coats of primer, paint and clear and this really helped speed up the process.
    - I wasn't totally happy with the texture and shine after the clear coat had dried (it felt a bit rough) so I polished the wheel with some Menzerna FG500 (pretty abrasive). I did this around 8 hours after i applied the last coat of clear and it was pretty hard.
    The only problem that I had was the guy on the phone at Autobarn was telling me that BMW paint code 354 didn't exist. I went into the store, found someone that knew what they were doing and got what I wanted. It reminded me of this:
    https://www.youtube.com/watch?v=XFWeoxrhbE8
    Jan 2012
    Epping, NSW
    Haha, love Ron Swanson from parks and rec.
    Jul 2009
    Quote Originally Posted by kahle81 View Post
    Sorry didnt see this till now.... Glad to know someone has made use of my thread!
    Good on you for adding your own tips. Yes you are correct!! The clearcoat finishes a bit rough. How did you apply the menzerna? Never heard of it, but after a quick search looks interesting.
    Skoda Octavia Mk3
