Results 1 to 3 of 3
Thread: Headlining Replacement Brisbane
    Brisbane, Queensland
    Hi guys,
    I need to replace the headlining in my Mk3 Golf VR6. The carpet has been ripped off, and the board is basically destroyed- plenty of holes and engravings in it.
    Any suggestions as to where I can have it replace/new lining put it in Brisbane? Any ideas on the cost as well? I was hoping for it to be less than $150 or so.
    Thanks,
    Ben
    May 2010
    Wellingtonpoint Qld
    If the board is in ok condition its not too hard to recover it... if the shell is trashed you will have to source one from the wreckers.If you are lucky it might come in good nick!!
    History... RX2, 180b sss, HK Monaro, VB commodore, VL turbo, VN SS, VT SS, FalconXR6 Turbo, Mk6 GTi..... phew
    Feb 2007
    I did my headlining a few years back and it wasn't too difficult. It was quite brittle and cracked only slightly when I removed it, but it was mostly in tact and pretty easy to re-cover. I'm not sure about getting a new one though, I'd imagine it'd be difficult to get a second hand one without it getting damaged in transit. Good luck with it all.
    Mk3.Mk4.Mk1
    My Mk1 Project
