Results 21 to 30 of 31
Thread: Headlight Restoration - Dans Method
  1. #21
    Adelaide hills, SA
    Quote Originally Posted by Dyldo View Post
    If i used the Mother's Platic Polish kit, then would I still need to seal the headlights with a product like Z2?
    No, it has UV protection. I'd just re apply it every 6-12 months, preferably before summer.
    Sent from my HTC Desire using Tapatalk
  2. #22
    Castle Hill (Sydney)
    Mothers Plastic Polish is supposed to have polymers in it which would protect the light. So no you wouldn't.
    Edit: Sorry didn't see Transporter's post.
  3. #23
    awsome i do the same thing..but the only difference depending on the customer i clear coat also..last longer..just an idea..i wetsand up to 2000 grit then clear um
  4. #24
    Jun 2008
    Cronulla, NSW
    how does the sealant get applied? by hand or machine? do you let it dry/haze then wipe off?
    I am using the sealant from the Menzerna sample pack - Car Care Products / Menzerna / Exterior / Polish - Cleaner/Wax / Sealing Wax
    By the way, I did mine today in between suspension frustrations and here are the results.
    I wasn't overly attentive with making sure the previous cuts' lines and marks had been taken care of before moving on the next grit, but it appears to have worked. I now think I might have better than 1 candle power headlights
    From this (driver):-
    To this (driver):-
    and from this (passenger):-
    to this (passenger):-
    final front end:-
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
  5. #25
    Aug 2007
    Five Dock, Sydney
    this is awesome... I think mine will need some loving soon as well!
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
  6. #26
    Jun 2008
    Cronulla, NSW
    Trust me, if i can do it bloody anyone can
  7. #27
    Good effort Dyldo! The sealant can be hand or machine applied in your case. It depends on what sealant you use. For sealing wax you let it haze then buff it off.
  8. #28
    Jun 2008
    Cronulla, NSW
    I sealed it with this stuff:- Car Care Products / Menzerna / Exterior / Polish - Cleaner/Wax / Sealing Wax
    Does it have UV protectant so the yellowing won't happen?
    I think I realised my blunder - I didn't re-wash between polishing and sealing. As the car hasn't been driven, can I do this now?
  9. #29
    If your using that stuff then you dont need to rewash between polishing and sealing. It has cleaners that will remove the oils and leave a wax behind. Yes it has UV blockers but its not that long lasting. Something purely synthetic like Duragloss 105 or 111 or Finish Kare 1000P Hi-Temp paste wax would be better suited
  10. #30
    Jul 2010
    Gordon, NSW
    My headlights needs a clean might give this a go
