How does this compare to the Einszett 1Z?
Does it affect painted wheels?
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Sydney - Brisbane - Melbourne
Does not affect painted wheels or any painted surface for that matter (same as car paint, just your wheels!)
Comparison would be, much stronger and has a quicker working time. So overall i guess less is used? But all very similar to one another, some find differences and some marginally if not at all.
I use IronX and my wheels have been painted with 2Pac paint (same colour as the car) - no problem at all
I would say it's normally necessary to use a brush - maybe I don't wash the wheels often enough
I have now used Nanolex wheel sealant on the right side of the car - I will be interested to see how the next wash goes!
(Do not let the IronX dry on the wheels!)
Depends how bad your wheels are to if you require a brush or not.. 1 month of rain almost every day and a BBK i had to use a brush a little to agitate the dust. Saying that, i do clean inside and out and take wheels off every 3 months to clean inside properly.
Having a sealant on also helps the cleaning process as well.
