Results 1 to 10 of 12
Thread: Glue/Bond
    Sep 2006
    West Sydney
    Glue/Bond
    Hi guys,
    Just wondering if you guys have experience with sticking bits of ABS plastics together. What's the best glue or solvent bond to use when it comes to joining pieces of ABS plastic together? I'm looking into something that will hold very strongly as it may well be projected to a lot of debris and some sort of force.
    I have not tried going going out to look for something yet, so if someone can tell me that I can get what I want from, say, Bunnings, then off to Bunnings I go. However, if you have experience with this kind of stuff, I would like to hear about it!
    Cheers,
    Raymond.
    syncro Guest
    I'm not sure, but I think glueing ABS is a PIA. Have you thought of welding?
    Most of the chemical companies (Selleys, Loctite etc.) have a technical hotline where you can get advice on this sort of thing.
    Aug 2006
    Skye, Victoria
    araldite or gaffa tape* and fencing wire*
    *I'm kidding about these two
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    plastic welding is def the way to go...
    Feb 2007
    Sep 2006
    West Sydney
    Welding would be the best way to do it I suppose, but I have no access to a plastic welder. I have thought about buying my own but the lack of experience of using one and the expense involved with buying equipment as well means it's out of the question.
    It may be a good idea to call Selleys up! I'll give that a go and see what they say.
    With the Araldite, where would I be able to find their products?
    Thanks for the replies guys :thumbs_up:
    syncro Guest
    Go to a panel beater as they plastic weld bumpers etc.
    Camden, Sydney
    Liquid Nails, sticks everything
    Sep 2006
    West Sydney
    I'm looking into something that's sandable too! Are they sandable?
    T4er Guest
    Thumbs up
    Quote Originally Posted by rayray086 View Post
    Try a product from selleys' called "plasti bond, its a 2 part mix simmilar to bog, the strnger you want it the more hardener u use. within reason , u can get it at mitre 10 , bunnings, any hardware and it wont break the bank about $14 a tube. Cheers
