Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Getting sap/wax off windscreen?
  1. #21
    Jun 2009
    Quote Originally Posted by Martin View Post
    Not at all
    When I was eight years old it was my job to take the kettle out to the car (just boiled) and pour it over dad's front and rear windows in -8 degree frosts - did this for years, never had a problem
    zone toughened glass is very strong - even with chips in it
    It's physically and thermally stronger than regular glass
    Sudden impact, especially from something sharp, that's what will damage a windscreen
    Thank you for proving my point.
    Until people have actually done it then they can't comment on "damage that it will cause."
    This also isn't a new glass technology as i have done it to my 24 year old corolla.
  2. #22
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by team_v View Post
    Also note, I was 8 years old all of 42 years ago, definately not new glass technology
  3. #23
    Pacific Paradise QLD
    Not at all
    In actual fact that is the wrong thing to do because hot water freezes faster than cold water
    Proof of it here BBC - Richard Angwin's weather - the Mpemba effect
    Strange but true. I proved it lots of times as I lived in a cold climate with 25 Degree frosts.
    Put warm water on the screen and it almost immediately froze Put cold water on and it took much longer to start to freeze.
    Has been scientifically proved to be true.
    On a nature program recently it was proved by going outside in sub freezing temps in Alaska
    The guy threw a jug of cold water up in the air and it fell to the ground as water before freezing on the ground.
    He then threw a jug of hot water up in the air and it froze immediately and fell to the ground as snow.
    FACT
    Best way to clear screen is to scrape frost off with a credit card and turn demist on cool for a few minutes
  4. #24
    Dec 2012
    More pointless internet theory
    (we were actually discussing the question "would hot water on a cold windscreen cause damage or cracking")
    In the real world we were not trying to freeze water in the shortest time frame
    The hot water does melt the ice very quickly - that's what we wanted
    Yes, the hot water will also freeze fairly quickly - if you leave it on the windscreen
    (we don't live in a -25 degree climate where hot water will freeze instantly)
    You just the wipers a few times and then a quick wipe off with a cloth
    Additionally have the windscreen demister running
    It works just fine...
  5. #25
    Is not pointless theory is a scientific fact. Whether it works for you or not I dont care. I always used cold water and turned the wipers on. My old man would have killed me if I put hot water on a frozen screen but obviously he didnt know what he was talking about.
    Only was a milkman who had this problem every winter for nearly 30 years and never cracked a screen.
  6. #26
    Sep 2012
    Wonga Park, VIC
    who gives a f, the man just wants to remove sap from he's windscreen, we covered it.
    Hot water melts ice, correct
    Windscreens are strong, correct
    Hot water plus cold windscreen with already existing cracks cause it to break, correct
    The idiot that poured hot water on a cracked windscreen most definitely deserved the repercussions
    Cased closed, moving on to productive things now
  7. #27
    Jun 2013
    Leichhardt, NSW
    Coming from a detailing background, if it sap as in soft, simply wash the winscreen as required with hot soapy water. If it is thick as in has dried, wet windscreen and use a qood quality razor to scratch off. it may take u numerous attempts to get it perfect but really the only way to do it.
    Ive see ninstances where the sap is so bad we had to replace windscreens.
    Best advice, dont park it under the tree thats leaking sap....
  8. #28
    Dec 2012
    Quote Originally Posted by Swainey32 View Post
  9. #29
    Just an update. I got around to polishing my windscreen again with much better results. I wouldn't say the windscreen is as good as new (as there are quite a few very small stone chips) but all streaking is now gone and I can actually see properly when it's raining!
    Golf GTI Mk5
    APR Stage 1, APR catback exhaust, Carbonio CAI, HP torque arm insert
