Results 1 to 6 of 6
Thread: Foam Lance Replacement Bottle
    Nov 2010
    Kensington, Victoria
    I bought from CCP a foam lance about a year ago and now the bottle is broken. Anyone knows of any cheap alternatives for a replacement?
    [Current] Audi A4 B8 MY2013 2.0T Quattro - Lava Grey, Black Edition, S-Line, 19" TT-RS Wheels
    [SOLD] Golf GTI MK6 MY2011.5 - Candy White, 5-Door, Manual, Sunroof, Park Assist, 9W7 Bluetooth RVC, MDI, Dynaudio, RossTech MicroCAN, Bluefin Stage 2, LED Tails, VW Racing Panel Air Filter, 3" Eurojet Downpipe, Milltek non-Resonated Catback
    Mar 2010
    Have you spoken to CCP, they may be able to help you out.
    08 Golf GTI - SOLD
    Jun 2011
    Sydney NSW
    Personally I would never use foam or any sort of detergent under any sort of pressure to wash a car.
    The foam or detergent has a lower surface tension than water and under pressure will be forced into gaps, crevices and spot welded seams that even water under pressure will not be able to get into. Eventually the foam or detergent that becomes trapped will break down and initiate corrosion.
    Nov 2005
    Sydney NSW
    Quote Originally Posted by wai View Post
    BWAAHAHAHAHA...
    Foam Lance is not under any high water pressure... the high pressure nozzles are taken off to attach the Foam Lance
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Jun 2011
    Sydney NSW
    Quote Originally Posted by Gigitt View Post
    BWAAHAHAHAHA...
    If you are ok with it, then that's fine.
    Jan 2012
    Earlwood, NSW
    Quote Originally Posted by aVex View Post
    Bunnings have an Oates 1L plastic bottle with a compatible thread for about $2. You'll find them where the household cleaning stuff (mops, brooms, etc) is.
    Edit: I should've mentioned that the Oates bottle appears to be the same type/density of plastic as the original bottle.
