I would try and mount it in the boot where the first aid kit should be. This is by the left hand rear light. There is a couple of bolts there already and the may line up. Plus you can pull back the carpet to see what you are drilling.
On a side note years ago I drilled through the boot floor to fit an cd changer and drilled into the top of the fuel tank. f**kwit.
Luckily a big old self tapper fixed that up!!
