Results 1 to 10 of 10
Thread: Drill attachment polishers
    Oct 2010
    Melbourne, VIC
    Has anyone here used one of these and do they work?
    Here is an example of what I'm asking about Velocity Sanding & Polishing Kit - 125mm - Supercheap Auto Australia
    Resident grumpy old fart
    Jul 2013
    Caulfield, VIC
    Re: Drill attachment polishers
    Keen to see how these go to. Never buffed a car
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    Nov 2012
    Newcastle nsw
    Quote Originally Posted by kaanage View Post
    I have used a similar product,except I bought mine of eBay a while ago. I found these to be very hard to control the speed of the pads, I currently have a proper buffing/polishing machine. It's much easier to control the rpm, with the drill I found you have to push the lever/trigger at just the right pressure to have it at the desired rpm. My advice would be to buy a buffer.
    PSSsSshhhhh
    Nov 2012
    Newcastle nsw
    Quote Originally Posted by Orrgazmo1986 View Post
    PSSsSshhhhh
    http://m.supercheapauto.com.au/Produ...menuFrom=20605
    It's quite cheap and would be suitable for the weekend warrior
    This is the one I bought of eBay, it came with pads etc
    http://bit.ly/16APRMf
    PSSsSshhhhh
    Nov 2012
    Newcastle nsw
    PSSsSshhhhh
    Sorry the eBay link didn't work
    Dewalt professional 1100w it was $179 delivered and came with numerous pads
    PSSsSshhhhh
    Dec 2012
    Sutherland Shire, Sydney
    Ideally you want an orbital action...
    Apr 2013
    Chadstone, Victoria
    You would never do a whole car with a little drill attachment like that, but some of you have seen me use mine. I made sure the (cordless) drill can do at least 1500rpm, and got some decent pads to use with it, and I use mine every day polishing slight scuffs, scratches etc on customers cars.
    It's also not a bad size for headlights etc.
    The SCA pads are likely to be rubbish though
    Mar 2008
    Sunshine Coast
    Final Inspection actually sell dedicated range of pads and attachment for this.
    Converter drill attachment
    90mm pads to fit
    Meant for hard to reach places and touch up only.
    A dedicated DA/RO machine is better for a whole car detail but certainly an option for small areas
    Oct 2010
    Melbourne, VIC
    Beat me to it - I was just about to ask about that one!!
    I'm only looking to take out very light swirls in my bonnet plus some small deeper scratches.
    Mar 2008
    Sunshine Coast
    My RO died a while back (overuse) and I CBF replacing it so this was the best option for the spot work I needed to do.
    I tried hand polishing but on VW paint - nuppa. I don't detail liked I used to - new house has my interest these days so this was the easy way out for what I wanted to do. So far, has been perfect and the pads (with FI's CAP range of polishes) has been great.
    Just be careful as with these drill attachments it isn't random action polishing so you can cause hologramming etc if not careful and at worst, burning if stupid
