> plastic dropsheets are your friend.
> if you are inexperienced, I would reccommend acrylic rather than 2k - its very forgiving. If its a **** job, you just sand it smooth and go again, or sand it smooth and smooth and smootherer and polish.
> you need about a meter at the minimum beside what you are spraying, or you'll have a lot of trouble handling the gun with air line etc.
> have bits of cardboard handy.
> I wouldnt dampen the floor personally, I think its better to keep the humidity low if possible. just clean and vacuum.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
