Results 1 to 10 of 13
Thread: Cutting compound
    SPC Guest
    Cutting compound
    I sprayed my car with acrilic paint, have now left it for a month to shrink and just sanded it with 1200.
    Now ready to cut and polish.
    Anyone have suggestions for a good cutting compound. It was suggested to me to use Brasso (the one that comes in the tub) but I am not sure about that and suspect that their may be a better alternative.
    imported_brackie Guest
    Cuttinf compound
    I've been using "T Cut" for 40 years always with outstanding results.
    Feb 2006
    Hobart TAS
    I use t-cut too. It's awesome for bringing up dull old paint.
    The only problem is I can't find it anywhere now!!!
    Golfwise Guest
    K&H Buffing compound. at Repco or similar
    Golfwise Guest
    T cut is like old beetles,
    a thing of the past.
    brisvegas_golf2 Guest
    i use 3m cutting compund at work on all my acrylic paint jobs, and for a tip when useing acrylic i have found out on your second to last coat add a bit of 2k thinners to it and even more on ya last coat but be carefull cause the paint stays wetter for longer and just melts together better. if you are suspect just try it out, it really works my tafe teacher told me about it. and if you are going to paint plastics or vynal add a bit of oil to you paint makes it more flexabile
    Thinners and top coat
    Quote Originally Posted by brisvegas_golf2
    I've always done that too! The final coat needs virtually no buffing back if you get the mix right.
    Golfwise Guest
    Great tip thanks Bris.We have to be carefull with our drying times here in Tas as we are just a little colder.
    The oil one is interesting too !
    don't hold me to the oil one , my tafe teacher told me about it
    Camden, Sydney
    What kind of oil?
Similar Threads
  1. cutting springs
    By GoLfMan in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 30-11-2006, 09:21 AM
  2. 2001 16v cutting out
    By mk14wd in forum Polo Mk4 (6N & 6N2, 1995 - 2002)
    Last Post: 07-03-2006, 06:13 AM
