I bought this Cult Society rear number plate plinth(hidden lock) a few months ago and it finally arrived last week. Anyway I wasn't really happy with the way it looked, as I liked the look of the original and wanted the same only with the lock hidden in and under for a clean look. The cult society item sits a lot closer and more flush with the tailgate, and is also bigger and overhangs unlike the original.
Anyway I decided to take the plunge and cut up both my original and my nice new Cult Society plinth and try and put them together.
I haven't stuck the two bits together yet but when I do I will smooth it over and get the lot colour coded. This is how it's going.
mk2 GTi 16v
Corrado G60
mk2 GTi 16v
Corrado G60
looks good mate keen to see the results![]()
Ha ha yes it is a bit low at the moment, as I'd fitted the rear susension I bought for it, but have now fitted the fronts aswell and have raised the rear about 40mm and it's still very low, haven't been able to test it too much yet as I need some longer lower strut bolts(high tensile) and it's filled with junk that rolls around every time I go around a corner.
Also I haven't worked out what settings the dampers are on yet. It's slowly getting there.
Was really nice to meet you the other day Aus, hope you can make it along to the cruise the night/day before the DOVW.
mk2 GTi 16v
Corrado G60
The coilovers brand is DMS(drummond motor sport) they're aussie.They look fancy, ha ha.
mk2 GTi 16v
Corrado G60
Lets just say they were a bit more than your KW V2's, yeah they're height, rebound and bump adjustable.
mk2 GTi 16v
Corrado G60
