Results 1 to 10 of 12
Thread: Crystalised Bird poo? (doh)
    Aug 2011
    vic
    Just noticed some bird poo on my roof, i know i should have kept it clean, but it has been raining so much lately i havn't had a chance to do much about it.
    Anyway, its literally crystalised, i had a go at it and its like plastic welded onto my roof, whats the best way to remove this?
    sad panda
    melbourne
    your best bet would be to soak a small portion of soft microfibre cloth in a good quick detailer/ strong soap:water solution, leave the cloth on the bird poo for a few minutes, and hopefully wipe away.
    if not, i'd be guessing that your next plan of attack would be clay barring it.
    Aug 2011
    vic
    Quote Originally Posted by Buller_Scott View Post
    any idea what ingredients are in these? i havnt got any proper cleaning equipment where i am this week, just need something that wont damage the paint/clear coat.
    melbourne
    well, the strong soap:water mix ideally being proper car wash shampoo/soap. i wouldnt use dishwashing liquid etc.
    as for the quick detailer, it's just a last step product that you'd also use when clay barring.
    if you're near the city you're welcome to drop by - i've got the stuff you need.
    Jun 2009
    I think the bird poop has eaten away at the clear coat..
    Sorry. Too late. Is it level with the clear coat or above it?
    Sent from my GT-I9100 using Tapatalk
    Jun 2008
    melbourne
    Any chance you can post up a pic so when can have a better idea what you have to deal with?
    I'd try buller scotts suggestion but make sure it's warm water as it will help soften.
    If you have no luck with that i'd get a spray bottle and either mix in some carwash or some APC cleaner with some warm/hot water and mist it over the poo so it's stays on and doesn't rub off. Then grab either a soft detailing brush and after leaving it soak for a minute or so very "LIGHTLY" brush over it in one direction to minimise the chance of scratching the paint work.
    If you use APC it may remove the wax on your car so if you succeed with you probably want to clay bar the whole roof and re apply wax after.
    This is just how i would probably attack it,i know if it happened to me and it had effected or stained the paint at all i have a Ro polisher to hopefully correct the issue afterwards.
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
    Aug 2011
    vic
    Quote Originally Posted by Silver dub View Post
    thanks for the suggestions guys, i havnt even been home this week to try and sort it out!
    my friend suggested metho? would that be of any use? i actually have none of the products suggested above
    ---------- Post added at 04:54 PM ---------- Previous post was at 12:21 PM ----------
    Quote Originally Posted by vraptor View Post
    edit: metho worked fewf
    Jun 2008
    melbourne
    If you have used metho just realise you have probably removed all waxes and or sealants that are protecting the paint.
    I would highly recommend clay baring the roof and re apply a wax or sealant to protect the paint.
    White Scirocco R
    White MK3 Golf 2dr
    Aug 2011
    vic
    The whole car needs some good paint maintenence, the problem is i work full days, and every single weekend for the last 5 weeks has been pouring down with rain, i havnt got anywhere i can do it...
    melbourne
    where abouts do you live?
