Im not sure what the site says so here is my process.
I use 2 buckets and 3 microfibers.
1. put mf in first bucket. remove and wring out so its not dripping but fairly moist
2. spray 2 sprays of lexol cleaner on the cloth
3. work the cleaner into the leather till its lathered up nicely the lather some more
4. when your satisfied its clean wipe as much of the lather up as possible with the cloth then return this cloth to the 2nd bucket
5. wet the second cloth the same way as you did the first and use it to rinse all the clener off the seat. If this cloth gets loaded with product dip it in the 2nd bucket then wring it out then dip it in the 1st bucket (this will keep the rinse water clean)
6. Once you have rinsed the seat use another mf or even better a waffle weave, to dry the leather
7. Condition
