Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Brake caliper painting
    Dec 2006
    Kilsyth, VIC
    They look pretty good!
    I've sprayed a couple of cars now with mixed results. The Mk3 came up very well and seemingly lasted longer, the Cab was a bit of a rush job and has flaked off over the years (probably because I didn't prep well enough). Something I keep meaning to do again. I'm interested in trying out the paint on version since it's probably a little cleaner (and easier) than having to mask everything up.
    As for wheel caps, I went the other way after swapping wheels and finding that the stock bolt dust caps didn't fit anymore... chrome bolts
    Apr 2017
    belgrave victoria
    I can get black bolts for it but black wheel caps are much cheaper lol
    The caliper painter has a 2 year warranty on his work and told me it should be good for 10 years+ as he primes it does 2 coats of color puts the label on then 2 gloss coats over the top
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Apr 2017
    belgrave victoria
    Upgrading my brakes to golf r setup just got the new ones painted in Candy Apple Gold
    Brake caliper painting-20171010_160312-jpg
    Apr 2017
    belgrave victoria
    Brake caliper painting-20171101_180942-jpg
    They are on now looks good
    Dec 2017
    Any good workshops in Sydney?
    Apr 2017
    belgrave victoria
    Quote Originally Posted by THR300 View Post
    You will have to hunt around i found my one by surfing the net (found out they were a customer of mine )
    A lot of good quality paint workshops(ones that do custom painting) will do brake calipers not a cheap exercise but worth it
    Nov 2012
    Dulwich Hill
    was it difficult to pull apart all the sections you need to paint? then to clean and prime the parts?
    mine are filthy.
    Apr 2017
    belgrave victoria
    Quote Originally Posted by yeders View Post
    mine are filthy.
    i was lucky that i was upgrading my brakes to larger discs/calipers so i had them all separate and at the painters while still driving the car with the old brakes
    But yeah pulling them off and cleaning would be a pain in rear end worth it for the result but time consuming
