Stick it up on blocks for a couple of years
Not much you can do, bit like brake dust on wheels, just need to clean regulary.
Is there anything to keep them shiny and resist the exhaust dirt, mine get coated in soot pretty quickly.
When clean they look awesome.
*Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
Economy at 100kph =5.5L
Flipper Dog
Now - T-Roc R, Audi Q5
Try some of this Nanolex Spray Sealant
After the hard work of cleaning them, you can put a sealant on to help reduce dirt build up and they should stay cleaner for a bit longer and be much easier to clean. It will not last as long on Exhausts as other parts (it is good for paint, wheels etc) because of the heat but it will definitely help.
Cheers,
Mike
Car Care Products Australia
www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
Sydney - Brisbane - Melbourne
I use " purple metal polish " extremely quick and glossy as !!!
WD-40 and denim rag.
Then some cheap cut/polish.
Anything you put on there to seal it, so to speak, will bake off in no time really. However, if chrome is nice and clean it will stay clean for longer
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
I always find that a little bit of waxing always keeps them shiny for a little bit longer. As Dan said though heat will always be a killer here.
Cheers,
Trent
2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Sealants are usually a much better option in heated areas such as wheels...that's why wheel wax can't compare to sealants like nanolex and opti seal. I'd go for a sealant on the tips, and for the sake of them being cleaner I'd wipe them down every time I wash the car, and spray more sealant on!![]()
