Ofcourse! because you sell it right?
I've used both and have found no considerable difference between them besides the Megs one is $16 for 500ml and the Autobrite one is $24.95 for 500ml. And IMHO the Megs one has a slight edge over the Autobrite gel.
Sorry to bring up an old thread, just putting in my 2 cents to help those that research this topic in the future.
Regarding the gels, they're good but very tiring and time consuming to apply. It's also hard to get a consistent application with gels, they're hard to apply into fine grooves of tyres without elbow grease... but they do have a very good level of gloss and tyres come out the darkest or "blackest" with gels. Also you shouldnt get ANY sling if you use it properly and apply with an applicator and then a final wipe down after with some rags. Megs one is probably the best bang for your buck for the gel. The hot shine is a bit shinier than the endurance but it lasts a bit less (who would've thought that!).
The Aerosol cans are ok too, they're easiet to apply, although they will sling if you apply too much and don't wipe down. I find that the shine with cans don't last as long as gels. I have tried a couple and found the megs one gives the most shine but the Australian export/motortech (same manufacturer, different labelling) ones are the best value for money for $3 a can, they also give a nice matte finish and just make the tyres look black and new without being too shiny if some people prefer that. They also last a good 2-3 weeks until the next wash when they can be re-applied. I also find the Australian export ones make great dressings for the wheel wells and make them look black and new.
The liquid spray bottles I find useless, its essentially the same as the aerosols in terms of looks and performance but a less convenient spray bottle which makes a mess, gets all over the paintwork if you hold it away and if you hold it closer it bouces off the tyres and goes everywhere and you don't get a consistant application unless you go through half a bottle...
Getting to Tyre foams which are my preferred method, they're easy to apply and the final result looks cleaner and more consistant than all the others mentioned. Just spray on the tyre and let it sit for a few minutes. If you're planning to drive off then just give it a quick wipe so there's no sling, or if you don't want that hot shine, otherwise let it sit for an hour or 2 and bob's your uncle!
My pick of the bunch would be:
Meguiar's hot shine tyre foam > Australian export/motortecth tyre shine > Megs hot shine tyre gel.
Hope that helps.
