Results 1 to 7 of 7
Thread: autobrite snow foam lance problem
    May 2010
    WA
    Hi all,
    The metal gauze plug in my autobrite snow foam lance that is a year old appears to be clogged with solidified snow foam. It is responsible for mixing the snowfoam with the water to produce the excellent foam that these things are known for.
    see this diagram for the bit I'm referring to:
    Autobrite Foam Lance - Spare parts diagram. - Detailing World
    I have tried cleaning it with acetone, kerosene and boiling in water for a few hours but it still won't work properly. Any ideas on how to clean it?
    To buy a new one from Autobrite (including shipping) will cost about 25 pounds from the UK!
    I suggest people always run some water through their lance after using it to stop this happening to them. This should be recommended by the suppliers when you buy the thing but is not. A bit disappointing..... as I had no idea such a tighly-packed gauze plug was in the thing....
    Golf VI GTI MY13 Candy white/ DSG/ Detroits/ tint/ reverse camera/ parking sensors
    2016 Skoda Octavia 162TSI RS Wagon (Silver/DSG/Tech pack/ Black pack)
    May 2013
    I don't have one nor have I seen one but have you tried soaking it in washing powder? That oxi action gear get lots of stuff clean.
    Mar 2010
    Have you dismantled it to clean it?
    If you haven't and are feeling brave follow this guide:
    Servicing a Autobrite H/D foam lance - A 20 step quick guide! - Detailing World
    Or if you bought it from one of the local suppliers have a chat to them. They may be able to sort out getting it cleaned for you.
    08 Golf GTI - SOLD
    Sydney, Brisbane, Melbourne
    Definitely try give it a good service as unfortunately if you do not regularly clean them they can become clogged. We have been lucky ours is now over 3 years old no issues so far!
    If you do require a new filter or further help, you're welcome to email us on info@carcareproducts.com.au
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Sydney - Brisbane - Melbourne
    May 2010
    WA
    Quote Originally Posted by Wolfgang View Post
    I did take it apart. It does appear that gauze plug is clogged. It would be nice to replace the gauze but can't find anywhere in Australia that supplies the part. I bought it from Car Car Products..
    Nov 2005
    Sydney NSW
    have you contacted Car Care Products for spare parts yet?
    I'd also try an ultrasonic cleaner with some of the above mentioned solutions. Use a small glass with your filter and solution and put the glass into the ultrasonic cleaner water to try and unclog it. I use this method for cleaning lots of things.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by darkfriend View Post
    Did you see the post by Car Care Products just above yours?
    Resident grumpy old fart
