Results 1 to 4 of 4
Thread: 1Z Einszett ColourTec DeIronizing Wheel Cleaner (Brake Dust Eater!)
    Sydney, Brisbane, Melbourne
    Thumbs up 1Z Einszett ColourTec DeIronizing Wheel Cleaner (Brake Dust Eater!)
    1Z Einszett ColourTec Deironising Wheel Cleaner is now available @ Car Care Products - $17.95 (less with forum discounts!)
    1Z Einszett ColourTec Wheel Cleaner is a highly advanced cleaner that attacks brake dust, dirt, debris and road grime. The unique deironising formula particularly attachs and removes stubborn brake dust, dissolving them into a soluble form allowing easier removal and rinsing of your wheels.
    ColourTec Cleaner has been particularly designed for European and other Prestige vehicles that are known for producing excessive amount of brake dust due to softer metal brake pads and discs. Over time this brake dust causes a corrosive effect which will deteriorate the clear coat finish on your wheels.
    Using this innovative iron-dissolving wheel cleaner change your wheel cleaning ways forever, because it requires little or no agitation and you can let the product do the work for you! Of course wit less agitation and better cleaning ability this means less chance of marring or damaging the wheels during the cleaning process.
    This wheel cleaner is safe for all wheel types including clear coated wheels, factory wheels, 2 piece, 3 piece, alloy, custom alloy and polished alloy wheels. This also can be used on Ceramic Brakes found on such cars as Lamborghini, Ferrari, Porsche, Lamborghini, Audi, etc.
    Car Care Products Australia
    www.carcareproducts.com.au - 1300 006 007 - info@carcareproducts.com.au
    Sydney - Brisbane - Melbourne
    Jun 2007
    Sydney, Australia
    How does this product hold up against the Wolf's chemicals decon gel?
    I noticed the price for the Einszett is cheaper by a few dollars.
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Oct 2010
    Melbourne, VIC
    I would actually like some sort of ranking or recommendation of the wheel cleaners (and other product categories for that matter) so we can choose the most suitable product for our situations. The manufacturer descriptions pretty much say they're all good in all situations - eg
    1Z Einszett Felgenreiniger Wheel Cleaner is a powerful wheel cleaner for use on painted alloy and steel wheels.
    Felgenreiniger Wheel Cleaner contains sophisticated cleaners that remove oil, grease, tar, and baked on brake dust from the wheel surface. For particularly dirty wheels some agitation will be necessary to clean stubborn brake dust and tar. Use a Vikan wheel brush, the softer the better, to gently clean between spokes, in corners and around wheel nuts.
    1Z Einszett Felgenreiniger Wheel Cleaner should only be used on cool or cold wheels. For best results do one wheel at a time, do not allow the product to dry, dwell time should not exceed 1 -2 minutes. If doing painted brake calipers test in a discreet area prior to use to ensure colour isn’t dulled.
    How would you choose this over the ColorTec (or vice versa)
    Resident grumpy old fart
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Flipper Dog View Post
    I found your answer by CCP on another forum
    The real differences i would say are more that this offers quicker cleaning and react faster, but also allows grime/dirt/grease to be cleaned where others you may find work well with brake dust but thats about all.
