Results 1 to 5 of 5
Thread: Bosch Auto Shop - Range Expansion!
    Hi all,
    Just thought we'd update you regarding our online range expansion. We've had a lot of emails coming through requesting various Bosch auto parts, so we're in the process of supporting each and every request.
    Online soon will be the following Bosch parts:
    - Filters: oil, air, fuel, cabin
    - Battery chargers and testers
    - Gasoline products (Bosch Motorsport pumps and injectors etc)
    - Timing belts/kits and drive belts
    - Electronics (switches, connectors, relays, horns)
    - Lighting (globes, lenses etc)
    Much of this will be available progressively in the next few months.
    Thanks!
    The Bosch Auto Shop team
    Boronia VIC
    Sounds great, will you be including the following spark plugs?
    F3CS
    F5DTC
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    F3CS
    F5DTC
    Hi Peter,
    These are very rare plug numbers, but we do currently have the F3CS (x 4) in stock, it's just not flagged for the online shop. We can set this up very easily, though.
    Regarding the F5DTC, this is a special order from Germany and not held in stock within Australia. If you do need this plug, please let us know and we'll enquire about the time involved with a special order.
    Boronia VIC
    Thanks,
    I've managed to find supplies of both overseas initially, but it would be good to be able to source them locally.
    The F5DTC plugs are a once off requirement for breaking in a motor.
    The F3CS plugs I need a fairly consistent supply of for a high compression race motor.
    I'm surprised that there isn't more demand for the F3CS here as it's a common plug for racing Porsches.
    7? MK1 Caddy
    12 Amarok
    Hi - i just sent an enquiry through your website. Im trying to source a MAF sensor to suit my parents Volvo C70 (2.3L 5cyl turbo). The MAF is a Bosch unit and the part number is # 0280217107. (I believe this part number includes the MAF sensor and the plastic housing that the MAF is screwed into). I really only need the sensor but will buy the whole section if required.
