2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
"Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
Hmm, I'll come out and have a run, I'l also be leaving burranda around 4ish jasn78 if you can bail a little earlier??
Sounds like I shouldn't take her for a run...
Oh and the whole breaking traction thing: I heard that it is extremely sticky and you just get bogged down, or destroy the clutch. But how do you break traction, like enough, in a R32?
MkIV .:R32 #197 of 200
2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Might be able to make this today.
06 GTI MK5 Tornado Red, APR Tuned; ,
09 Tiguan TDI MY10, Black, Fog Lights, Tint, MDI, Bi-Xenon, Dynoaudio, Parking Assist, Rubber matts.
Getting an AWD car off the line fast requires one of two methods:
1. Lots of revs, drop the clutch and hope the drivetrain doesn't spit the dummy and break.
2. Medium revs, slip the clutch for the initial 'bite' of the clutch so the car has a little momentum, then drop the clutch. You'll burn your clutch a little, but it will save the gearbox/diffs/driveshafts as a result.
In my WRX I always went for option #2, as a new clutch is FAR less expensive than a new gearbox.
Edit: But yeah, only just noticed this thread... will have to try and come along to the next test'n'tune instead.
Previous Rides: Polo GTI, Mx5 10AE, MY05 WRX WRP10, Renault Sport Clio 172
Current Ride: Evo 8 MR, Fabia MK3
I've heard stories of at least 5 or 6 dead MkIV R32 clutches but none on the rest of the drivetrain. Don't know how many runs were done or what the launch technique on them was. Clutch is enough of an expensive hassle as it is.
I think quozl's technique for the fastest launch was around the 5.5k rpm mark. Not sure if it was a option 1 or 2 in terms of clutch control. I'm pretty sure it's posted somewhere on here though.
Cheers,
Trent
