Machine is an old hand to track work and achieved great times on track. He knows what to do. He also used to run these events.
I’d hate to cook my tyres. What about traction control? Do I have to leave it on? And even though it’s not a race, I’ll have to wear my new race suit and helmet that I bought just for Happy Laps, because I want to be really safe.
Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
Not recommended, unless you're running semi-slicks (R compound). The sidewalls of any street tyre, even high performance, generally need the extra pressure to stand up. It's fine, though, because like Mattlock said, it's not racing, but I'd be surprised if you said your car didn't "feel" better in the corners with adding 5 psi above cold road pressures.
Dropping the pressures even more severely will cause the sidewalls to collapse and the shoulders to roll over, potentially causing the bead to unseat and come off the wheel, resulting in catastrophe. It's happened on the track with underinflated rubber.
Not saying you're wrong, but I am a bit surprised because that is the opposite of what I've read pretty much everywhere, and from my father in law who has been in motorsport for 30 years (owned & ran a V8 supercar team). My understanding being that by dropping slightly below cold road pressure, the heat induced will raise the track pressure back to a few psi above cold road pressure. For example I run 280kpa on the road as per the tyre placard, but will drop back to 260kpa for track days (cold pressures). I haven't measured them (maybe I should) but in theory the hot pressure should then be around 300ish ... unless my engineering degree was a waste of money that's the theory side at least 😂
Some people like to corner hard as soon as they go out on track. This is why we say bump up the pressures so they don't roll the bead off the rim. With good high performance tyres if you are sensible and wait for the tyre to pressure up before going hard you can run with a few psi lower starting cold pressure. This way they wont over pressure and less likely to start losing grip from too high a pressure when hot later in the session. This is my experience.
