Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 80
Thread: Lakeside Raceway Brekkie and laps - Saturday August 4 2018
  1. #31
    May 2013
    ARGH. This just makes me hurt being car-less even more!
    Paul, I should have a car in time for this one - a 1988 Caterham Super 7. If you’re up for letting me out, I’ll take a reserve spot and will confirm nearer the time.
    MY08 Mk5 GT Sport - sold
  2. #32
    Apr 2013
    The Gap, Queensland
    Keep those payments coming please. Only 4 more days until all payments are due.
    Paul
  3. #33
    Apr 2013
    The Gap, Queensland
    All payments are due TODAY and quite a few payments yet to come in.
    Paul
  4. #34
    Jul 2011
    AU
    Hi Paul
    Mine and Levi's went in over the weekend so you should have them today or tomorrow.
  5. #35
    Apr 2013
    The Gap, Queensland
    Thanks everyone for the prompt payments. Remember you can buy passenger passes on the day @ $20 each please bring correct cash.
    Paul
  6. #36
    Jun 2016
    Hey mate,
    Please add me to the Reserve list +1 passenger.
    I'll PM you my phone number so you can call if need be.
    I'll bring cash out if I'm running.
    HPRS230 - Grey Skoda wagon (TDI...)
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  7. #37
    Jul 2012
    Gold Coast, Qld
    Brake bleed - check.
    What else do I need to do? I tightened wheel bolts to 9 ft lbs. Seems like a lot
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  8. #38
    May 2013
    I’ve never tightened up wheel nuts. Remember this is happy laps so you’re not really putting too much strain into the car in the corners.
    I do, however, check all my fluid levels and inflate the tyres by about 3-4 psi above my normal running pressures to help the tyres cope.
    Sent from my iPhone using Tapatalk Pro
  9. #39
    Jul 2012
    Gold Coast, Qld
    The more strain in the corners, the happier my laps
    I’ll definitely check all fluid levels to ensure they’re at the bare minimum. I don’t want to be carrying excess weight. Same with tyre pressures. I think the more air in them, the heavier they’ll be, so that will only increase unsprung weight.
  10. #40
    May 2013
    Errr, no.
    You want your tyres with a bit more air in to make them move around less and overheat. If your sidewalls are soft, it will add more roll to the car and you will cook your tyres as the tread blocks will move around too much generating heat.
    As for running your fluids at minimum - sure it’s lighter, until you go round a corner and starve a pump because everything has sloshed to 1 side.
    You’re not on these laps to break lap records and if the marshals think you’re getting carried away they will call you in or stop the session.
