Hey vwgolfer, I heard in the video you were saying that you didn't use manual mode because it doesn't hold the gears.
It should hold the gears. It will upshift if you go past redline but to be honest if you get that far you've gone past the optimal rev range anyway.
It will also downshift but only if you plant it past 9/10ths. The accelerator pedal has a point at about 9/10ths where it almost stops but if you push further, you feel it almost click, it is this point at which it will downshift automatically. At 9/10ths it is still full throttle.
I use manual mode on the track. I think driving it in auto mode would drive me crazy!
