How often do these happen? Put me down for the next one please.
Dev.
Wow! The best session...that's great.
It was good to do HL again. I got to try lines I don't usually take during TA.
With AD08R, you'll find a broad range of recommended pressures. Personally, I've found 33 was too low, so 34 was my bottom. But I've run 37 and 40, too, with success, so it might come down to a bit of experimenting on your setup and what feels the best. A probe pyrometer is also good to make sure they're reaching operating temp or not overheating. Differences across the tread might also help you dial in camber settings. I did a lot of that measuring data stuff on my AD08R's, which helped when I moved on to true R comp's. But it is tedious![]()
Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
Dev.
My in car from Sunday...
https://youtu.be/Mn0UWBiKXiU
for all your race wear items. gloves to elmo's suit
Racedeal.com | Quality Brands. Best Prices. Winning Service. - Racedeal.com
show him the elmo's suit Mach Ine![]()
MINI Cooper S Clubman - FWD
Sweaty hands is actually why I came in a few mins early! I need some gloves. Or maybe my next car will just have an Alcantara wheel, eliminating the problem...!![]()
a clip from me. raw and unedited. MA+ rated... or PG
