cant believe you got a vr6 for 200. Anyways, my Scirocco is a DNA stage 1+ tune. Same tune as I had only last years Dyno day which netted 191kw, after a Dump pipe and hpfp netted 221... pretty good gains for about 1k in mods.
Thanks for the pics stary. Have you worked out the real torque output yet?
1996 VR6 Golf
2012 MY13 Scirocco R, DNA Stage 1+, Volant CAI, SPM Dump Pipe, HPFP, 221kW.
Stary's Scirocco R Journey
A quick google nets me:
HP = Torque x RPM ÷ 5252
221.6kw = 297hp
hp * 5252 / rpm = torque in ftlb
so 297 * 5252 / 3500 (this is where my torque peaked) = 445.7 ft lb = 604Nm?
probably should be using torque at peak HP RPM
so 297 * 5252 / 6000 (this is where my power peaked) = 260 ftlb = 352Nm?
Second figure looks more realistic, but can someone confirm.
Edits:
Or is it using the values at where Torque Peaked,
which gives you approximately 160kW @ 3500rpm
160kW = 215 hp
215 * 5252 / 3500 = 322.6 ftlb = 437Nm
Which seems about right??
Last option is right one.
Get the HP & RPM at the peak torque point - that is the right combo. 437Nm sounds reasonable gains over stock for a Stage 1 with the mods you have.
If I were you, next goal is to get that torque peak to last longer and not tail off so much toward the higher RPMs.
Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
