Sorry guys due to unforseen circumstances I can make it. If I end up with some spare time I'll try to get there. What time is closing time?
OK we have the start list finalised.
If you have specific requirements for timing of your run please see me when you arrive on the day and we'll look to accommodate as best as we can.
Also as per past years there will be a BBQ for a gold coin donations. Bacon and eggs for breakfast and sausages for lunch.
Oh and Phil has promised to bring down his coffee machine too
great day guys and good turn out! thanks for organizing again Tigger!
DYNO DAY RESULTS:
Model Power Mods Mk6 GTI 158kW Spectune Stage 1 Amarok 420TDI 117kW Stage 1 Mk7 R 172kW Stock R36 166kW Stock Mk6 R 205kW Giac Exteme Stage 2+ Mk5 Jetta 214kW APR Stage 2+ (K04) Scirocco R 221kW DNA Stage 2+, DP, HPFP, CAI Mk7 110TDI 96kW Stock Mk5 GTI 124kW intake Mk5 TDI 111kW Stage 1(?) Mk7 GTI 198kW APR Stage 1 Mk6 Golf R 204kW Spectune Stage 2 Mk6 Golf R 196kW APR Stage 1, Intake Mk3 VR6 108kW Stock Polo GTI 1.4l 104kW Stock Mk2 Octavia RS 127kW Stock Polo GTI 1.8l 9N3 92kW Stock+ Mk3 Variant 58kW Stock
Did anyone pay attention to torque readings?
The GTI Stage 1 torque really surprised me. It got 610nm.
Yeah there was a sheet going around which explained what the values you were getting. The number you're looking at is actual torque at the wheel. This is the raw number direct from the dyno.
The number people are used to seeing is the derived torque or (calculated) engine torque. The RPM and gearing are used in calculating this number. On a dyno this number can be a bit "rubbery" so that's why they prefer to give you the "raw" torque figure.
610nm is about 2.5times the actual torque that car would be making. Derived torque is much more realistic.
In other words, unless you do before and after the tuning on that dyno, the numbers don't mean much.
108kw at the front wheels from a stock VR6. Geeeez thats a healthy motor!
