Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 81 to 90 of 102
Thread: Dyno Day II - 8am Saturday 24th May
  1. #81
    Ok I spoke to Brett who is the guy that usually runs the dyno (he was away unfortunately) and to get the derived torque figure he needs to know what RPM each run was done to. He can then punch this in and get a value for derived torque - which is more meaningful for most people.
    So if you want this value send me a PM with the redline cut-out for your run and I'll see what I can do. Otherwise if you know engine RPM to road speed we could do it that way too as the road speed was recorded on the dyno.
    Nov 2012
    S.A. Gawler
    7000ish rpm for me, does that help?
  3. #83
    May 2013
    Darwin
    Quote Originally Posted by Ozrodent View Post
    Same as me
  4. #84
    Yes that'll do. Because max torque happens a lot lower in the range any error at the top gets reduced.
    Nov 2009
    Or you can use this forumla.
    Torque (N.m) = 9.5488 x Power (kW) / Speed (RPM)
    Except I just realised the graph is kw v kph?
    Volvo S60 RD T6
  6. #86
    Apr 2013
    Thanks for everyone turning up and running their cars today - perfect weather for it too. Another great day to own a VW.
    A few people left scratching their heads trying to work out where they are missing kW, however the dyno has been calibrated by Mainline only last week so today's figures should be right on the money.
    Anyway here's the results from today's dyno day in running order:
    Year/Model Performance Modifications/Tune Power(kW) Torque (Nm)
    2012 Polo GTI Stock 110.5 408
    2013 Polo GTI ABT Stage 1, CAI, CBE 118.8 470
    please note torque figures are uncorrected.
    Yes lots of head scratching on my part as to where 10+kW went (2013 Polo GTI on chart above) although the AFR figures on the charts point clearly to the problem. Soon after the AFR dropped below 12 to 11.5 on my chart the max. power levelled out and stayed there not dropping off until the red line (I was watching the tacho in the car). Denning's chart shows the AFR stayed marginally higher at a low around max power of 12 air:fuel.
    The dyno operator and my mechanical engineering background (I'm no engine tuner but remember from my practs. I did on engine tests at uni a million year ago) tells me 11.5 AFR is way too rich. Yes I realise VW/ABT are very much about protecting this 'fragile' engine.
    The dyno charts are with ABT in Germany now and hoping for a positive outcome.
    Incidentally I ran the fuel tank down for dyno day and filled up, at a busy high turnover outlet, with 98PULP just before the test.
    Attachment 9960
    Attachment 9961
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
  7. #87
    Jul 2013
    Adelaide, Australia
    I think most tuners tune to around 12:1 AFR or lower for tunes to be safe. My graphs show my stage 1 starting off ridiculously lean for some reason (24:1? the tailpipe sniffer probably wasn't aligned properly) but evened out to 12:1 for the higher rpms...
  8. #88
    Feb 2014
    Looking at the stock standard car's results, they appear to be around the mark in relation to SAE specified factory engine output, so don't really think the dyno is 'out' and appears to have been calibrated.
    Are people annoyed on lower figures based on a previous dyno day or something? Many factors coming into play that could have affected the results on two different days, including the 'ramp rate' programmed by the dyno operator which will alter the power reading.
    As to 11.5:1 AFR, I don't see any concern regarding that given the increased boost levels (from the ABT tune), (assumed) factory intercooler and high load situation. Assuming you're making the comparison against the stock polo AFR result (approx. 0.5 difference), which would be running slightly less boost and running a bit cooler intake air as a result. Its just the ECU compensating for the increased heat as a result of higher boost and trying to protect the engine... a larger intercooler would aid bringing down the intake temp and adjust the AFR a bit leaner.
    My last car (ralliart colt) which had a remap and increased boost (19 psi) was running something like 11.4:1 at full noise and full load, but was on a standard side mount intercooler. A similar car (tune wise) but with an aftermarket front mount IC core was safely achieving 12.1:1 at full load.
  9. #89
    I have some of the derived torque values for those that wanted them.
    APR Stage 2 Ed35 - 212.9kW/408Nm
    APR Stage 3 Jetta (K04) - 212.2kW/407Nm
    DNA Stage 1 Scirocco R - 190.6kW/341Nm
    Also if you would like a pdf of your new torque curve with RPM and derived torque please PM me your email and I'll send it through.
    The power figures for the dyno are quite accurate as the dyno was calibrated by Mainline techs only the week before the dyno day.
    I think that last dyno day some of the figures may have been a bit more "generous" for whatever reason. The main benefit of the dyno days is that you can compare results across a range of (similar) cars all run on the same dyno on the same day. This is about as good a comparative data that you can get from dyno testing. Comparing results from different days is possible but given the dyno was recalibrated between runs it may be difficult to compare these 2 sets of results.
    Nov 2012
    S.A. Gawler
    Thanks Damien, still stoked with the result
