Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 102
Thread: Dyno Day II - 8am Saturday 24th May
  1. #91
    May 2013
    Darwin
    Thanks Damien I will pm u my email
  2. #92
    Apr 2013
    Just PMd you Damien.
    Sorry to be a nuisance but can you also give me some info. on the FAR numbers (at peak power) for other cars on the day?
    I have done some research and 12:1 OK but 11.5:1 seems too low even for a turbo with extra boost.
    2015 Polo GTI with DA pack : Milltek Turbo back exhaust | DD spacer | JB1 | VWR Turbo Intake elbow and intake hose | BMC panel filter | KW Street Comfort coilovers | Whiteline adjust. endlinks | Harding DSG Perf. tune | Wagner Intercooler| Dotz Mugello 17 x 8 32ET
  3. #93
    Quote Originally Posted by car_nut View Post
    Do you know what the max RPM your car (and the other Polo GTI) ran to?
    I need this info to get the new curves plotted.
    Also on AFR 12's seem to around what APR runs at. I previously had Viezu and they ran around 11's so a bit richer but definitely safe.
    Each tuner will do something different but the twin charger people are generally more conservative.
    Apr 2013
    PM'd you again - please ignore.
    Thanks Damien but ABT Germany just sent me a heap of technical jargon and questions including an ABT Polo GTI uncorrected data dyno chart - I need to speak to the dyno operator anyway so please do not waste any more time on my data.
  5. #95
    Jul 2013
    Adelaide, Australia
    Thanks for quick turnaround Tigger!
  6. #96
    Anyone else after an updated dyno chart with RPM instead of km/hr? plus "derived" torque figures.
    Just PM me your max RPM and email address and I'll arrange to send it through.
    If we get a few done I may even update the torque figures with the "proper" numbers.
    Nov 2009
    Are you talking the max rpm as per the manual or do we need to flog the car and hope the rpm gauge is right? Damn I wish I had a vcds type program form the bimmer!
    Volvo S60 RD T6
  8. #98
    Quote Originally Posted by thezoneR32 View Post
    Just what maximum revs (approx) they ran to on the dyno.
    Apr 2013
    I changed my mind again! I have probably confused you but if you can manage it I would like an updated chart with RPM thank you.
    Max revs was I assume 7,000. I did a 'test' today and at a steady 100km/hour in 4th gear the tacho. is showing only 4250rpm.
    From interpolation max. power was therefore 118.9kW(quoted) at less than 4,500rpm (quoted at 102km/h on chart)- very pleased with that. Could have been a very good number if the gremlins hadn't stopped it rising.
    Did what Gavin of Custom Code (thanks again for referring him to me for advice, hell of a nice fella) suggested I do and accelerated hard in 4th gear, from about 3000rpm to red line, and it pulled like a train without any apparent drop in acceleration rate. What a difference normal air flow through the front of the car can make!
  10. #100
    No problem I'll get those charts sorted. And yes unless you're logging just about every engine parameter it can be hard to work out what is going on. You may end up chasing your tail for a non-existent problem.
    The real test is on the road and how the car drives both everyday in city traffic as well as when you give it a few beans in the hills/open road.
