Page 51 of 183 FirstFirst ... 41495051525361101151 ... LastLast
Results 501 to 510 of 1828
Thread: Adelaide: Monthly Coffee and Drive Meet - Discussion Thread
  1. #501
    +1, I cringed reading it.
    Although I would hope that near redline in third is within the recognised speed limits.
  2. #502
    Feb 2014
    i guess 200+ kw was more then the lil engine could handle :/
  3. #503
    Nov 2009
    Quote Originally Posted by milldinho View Post
    Won't be making it to cruise, my engine blew up last night, I was in 3rd close to redline, then bang!!! For about 30seconds The darkness of onetree hill road was no more. Thought I was going to watch her burn. Later upon inspection Saw that cylinder and rod punched a hole through bottom of the sump.
    DAMN!
    Stage 3 is getting to that point where you need a strengthened bottom end and internals, but you don't hear about this sort of thing happening too often. Such bad luck mate. Hopefully the rebuild won't be too exxy. Look on the bright side - this is an opportunity for you to go for bulletproof internals and chase even more power - if that's your bent!
  4. #504
    Feb 2014
    Ouch!
    What sort of tune was it (which company) and who tuned it?
    I was certainly surprised by the result from your jetta on the weekend.
    Could be a multitude of reasons for the blockbuster, but out of curiosity what were your AFR's like on the dyno sheet after Saturday's run? And what sort of boost level was it running?
  5. #505
    May 2013
    Darwin
    Quote Originally Posted by wombat1978 View Post
    Ouch!
    Good afr 12:1. And about 22 pounds boost, I'm running everything APR, I was very surprised
  6. #506
    Surprised is an understatement! I should think that you're devastated given how much you've put into it.
    So where to from here? Hope you're able to get it fixed and back on the road.
    May 2013
    Darwin
    I'm devastated too, I'll have to rebuild it I guess
  8. #508
    Nov 2009
    If it was running lean and hot you'd expect to see detonation, loss of compression, piston damage, blown turbo etc, and not rod/crank damage (unless there was oil starvation happening maybe). The good AFR backs this up. 212fwkw is a lot of power for the stock internals, and a huge hike from factory. Hopefully when it's stripped down the ultimate cause will be found... maybe a manufacturing defect?
    Good luck with the rebuild mate - I'm sure you'll get it back to health again soon.
  9. #509
    See everyone in a couple of hours. I've heard that we may have a special guest appearance with a Mk7 Golf R this morning...
    Nov 2012
    S.A. Gawler
    That'll be nice, to see one up close
