Page 21 of 183 FirstFirst ... 1119202122233171121 ... LastLast
Results 201 to 210 of 1828
Thread: Adelaide: Monthly Coffee and Drive Meet - Discussion Thread
  1. #201
    Did you say you wanted to end up at McLaren Vale?
    Bull Creek Rd is another great one if we are going out that far, and perhaps from Mt Barker, head up hawthorn rd to echunga rather than flaxley, it will be too busy. PLus hawthorn is a great mini rally.
  2. #202
    Nov 2009
    Quote Originally Posted by rennsport View Post
    The main concern about ending up in McLaren Vale is that people still need to get back, so if we make it 120km+ to get there, that may push it over the line for some people, whereas a start and finish near the city is a bit more accessible. Having said that, I'm happy to go further. What do people think?
    Here's an alternative route, that takes in the roads you and Rhys mentioned, and ends up in McLaren Vale at Blessed Cheese (a fantastic cafe and lunch spot):
    Option 2: http://goo.gl/maps/rjhxN
  3. #203
    Adelaide hills, SA
    Yes, it's a bit of on the longish side, so if I go I will join you somewhere down south.
  4. #204
    Nov 2009
    Well, I can reduce it some? If we ended up near the city, what sort of length would you like? And if we ended up in McLaren Vale, what length?
    We can always decide on the day, but given the relative complexity of the route some maps wouldn't be a bad idea, in which case deciding beforehand would definitely help.
  5. #205
    Well for me personally it would make my life easier if I was home by lunch time (back in Semaphore by 1pm).
    I wouldn't mind starting a little earlier if we went a bit further but need to finish somewhere nearish to town around 12.
  6. #206
    Nov 2009
    Might be tricky to start too much earlier, being a Sunday morning and all. The meet is for 9:30.
    Here is a slight modification of the first route (I'll call this Option 3), that includes Hawthorn Rd, but doesn't go as far south as Mt Compass or as far west as McLaren Vale; it should get us back to near the city by close on 12ish:
    Option 3: http://goo.gl/maps/uIdkP
  7. #207
    Quote Originally Posted by AdamD View Post
    Option 3 looks good - and I can bail out at Clarendon/Chandlers Hill depending on how time is going.
    Aug 2007
    Option 1 or 3 would be fine for me, 3min from home on start and finish points
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
  9. #209
    Yep option 3 looks good to me, I only referred to McLaren vale as it was mentioned earlier. Probably better to keep it manageable.
  10. #210
    Nov 2009
    Okay, as I've heard no dissenting views, I've updated the Announcement Thread.
    Hope to see plenty of people there!
