Results 1 to 6 of 6
Thread: Where is the Bluetooth module in 2010 cc?
    Aug 2013
    Hi guys,
    I'm planning to upgrade my Bluetooth module from 9w2 to 9w7...
    I have seen lots of posts and videos saying it should be under the driver seat in foam cage.
    I just can't find it there... Does anyone know where is it installed in 2010 cc?
    Thanks,
    Vexed
    Sent from my Nokia Lumia 1520 using Tapatalk
    Dec 2008
    Sydney/Canberra
    Premium Bluetooth was under the driver's seat.
    Not everyone ticked that box, though.
    The 'standard' Bluetooth module will be jammed in under the radio unit behind the heater/aircon controls.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2013
    That's not what I wanted to hear
    Will I still be able to access it and replace it with the new module? Is it accessable from behind the RNS510?
    Dec 2008
    Sydney/Canberra
    Yeah, you have to pull the radio and heater/aircon controls out to get it out.
    I can't recall if the Premium one will fit in there, or if it has to go under the seat. Either way, it's not a massive job. Just fiddly.
    '01 Beetle 2.0
    Aug 2013
    I always thought(assumed) that I have the 9w2 module, I thought this will be a plug and play thing... Thanks for your reply, I will see how it goes.
    Cheers.
    Vexed
    Aug 2013
    Found it
    Thanks mate, as you said, it is behind the Air Con controls, it a Volk-L bluetooth model. from what I read, the upgrade is plug and play, fingers crossed.
    Cheers,
    Vexed
