Results 1 to 10 of 14
Thread: V6 4Motion CC has poor throttle response - any known solutions??
    Mar 2015
    NSW
    I've got both a VW R36 and a MY12 CC V6. I'm selling the R36 but this car is my reference for handling, exhaust noise, and performance (as far as large family luxury sports cars go).
    The MY12 CC (fitted with some options & mods) is better in nearly every way except:
    1. Seats don't have inflatable side bolsters so, my small frame slides around when cornering moderately hard
    2. Exhaust is silent - surprisingly it doesn't make it slower than R36 (I measured), but it feels slower
    3. Handling, with Sport Mode and Eibach Sports springs (~20mm lower), is not sharp and the body rolls too much
    4. Part Throttle response is very poor
    Now, I realise the CC is more the luxury cruiser vs the R36 is designed to be a sports car, but I want the best of both worlds...
    I'm figuring the electronic throttle is tuned for economy because the car shifts up gears rapidly in D and, even with moderate throttle openings, the car goes NOWHERE. It's actually dangerous. Entering traffic from a side street, or turning in front of traffic are frightening. You either have no power, or you put your foot down and get too much power... Part throttle acceleration is sluggish!
    I have to fix this, whether it's DIY (preferable) or through a tune. Please point me in the direction of a fix if you know. At this stage, I'm thinking of intercepting the throttle wire but this is a bit of a hack.
    Jul 2013
    Hills District
    Sprint Booster?
    I think R36 beats CC in every way though
    Apr 2015
    Sunbury, Victoria
    Are you using the DSG in drive mode or sport mode? I found my MY12 V6 4motion CC is smooth and sedate in Drive mode but a different animal in Sport mode. Throttle response seems improved, holds gears longer and blips the throttle on down shifts. I've never driven an R36 to compare though.
    Mike
    Mar 2015
    NSW
    Quote Originally Posted by Passat R36 View Post
    Sprint Booster?
    Maybe a standard model, but not the MY12 V6 4Motion CC I purchased with the upgrades fitted (R pedals, R scuff plates, R steering wheel, Eibach Pro springs, gorgeous Nappa stitched leather, LED DRLs, full phonebook Bluetooth function, hard drive and on and on. I'll put up a full comparison at some point
    Quote Originally Posted by CSX66 View Post
    Mike
    Definite difference with CC in Sport mode, but in the R36, it's pretty wild (sound, response, urgency) but is too much for regular driving for fuel, noise and eagerness. I prefer Manual mode for sporty driving, or Drive for regular. It's the regular side that is very subdued feeling. I find I have to press throttle more and more as gears rise through 4th or down shift it. Something I don't do in the R36. It seems a different tune to either throttle, gear shift timing or fuel efficiency.
    At full throttle, it's actually a smidgen faster than the R36 (I measured with GPS based app). Could be wear on the R36 (76000km vs 27000k on CC)
    Dec 2008
    Sydney/Canberra
    Reset the DSG, and drive it in a manner that suits you, and it'll adapt to suit.
    There's plenty on Google on how to reset it.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2015
    NSW
    Will do, thanks for the tip
    Mar 2015
    NSW
    Well, I just found out that the previous owner had fitted (and removed before advertising for sale) a SprintBooster and set it to Green (moderate boost). So the ECU figured that the only way the throttle is going to respond is with large pedal travel....
    Seems I have to somehow, re-educate it. I did a quick search for throttle reset. Seems you need a VCDS / VAG-COM. Some are saying they got some success with a so-called "chicken dance" but this was on much older cars, so not sure.
    Any experience with this.
    PS - I did a DSG reset and it slightly improved things like moderately accelerating from rest where before I'd get a big hesitation then a jolt with a drop in revs.
    Dec 2008
    Sydney/Canberra
    Keep driving it, and the DSG should adapt to how you drive.
    '01 Beetle 2.0
    Jul 2013
    Hills District
    ah, ok, saw that CC on carsales, Congrates on the purchase!
    but you can not compare standard R36 with modified CC...
    btw, the LED DRLs does not cost $1000 as the previous owner claimed
    Dec 2014
    I got a Harding Performance DSG tune on my 6 speed wet clutch via one of their distributors (Volkspower) in Melbourne and couldn't be happier. It's expensive but it transforms the car. It really does what’s claimed. It makes the care more driveable. It holds gears for longer in D and holds gears for less time in S. It makes both D and S more useable.
    Previously when turning a corner around the city, the car would enter the corner in say 5th gear and stay in that gear on exit with no useable power. Several subtle throttle applications on exit would produce no results until the DSG suddenly jolted into 1st gear with lots of revs. With this upgrade the car changes down gears when entering a corner in much the same way you would yourself if you were driving a manual. When exiting the corner, the car is already in 2nd gear ready for effective acceleration. The upgrade prevents the DSG from dropping into 6th until 70 km/h. If you want more sporty changes, then S works well without being so manic as before.
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
