Is the button just in front of the gear stick, next to the Traction Control button ?
Press it for a few seconds while driving, it it will beep to indicate it has reset. Check the manual for the full instructions.
The system does not monitor the pressure, just the speed the wheels rotate compared to each other, the logic being if one goes flat that wheel will spin faster than the others.
If find it is completely useless, last pressure check showed 6-8psi difference between the tyres and no warnings at all.
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
