Results 1 to 7 of 7
Thread: Tyre pressure fault
    Feb 2017
    Suburb
    Tyre pressure fault
    Hi, first of all sorry for my pure English. Passat CC 2012 (1GEN)
    Please help me to find a reason for my problem. Some days ago, my tyre pressure monitoring has gone..
    First tyre pressure warning light comes on, but monitoring show what pressure for all wheels are good (OK). Then (that day) tyre pressure warning light turns on or off in no fixed time. And in end of the day, the tyre pressure warning light come on always, and the weirdest think is what tyre presure monitoring has gone, no longer avalable in MENU. No picture with car and no menu sub category "tyre pressure" (or somethink like that, I dont remenber how exactly it written). Then I connect VCDS, i got this faults:
    VCDS Version: Release 12.12.0 (x64)
    Address 17: Instruments Labels: 3C8-920-xxx-17.clb
    Control Module Part Number: 3C8 920 970 P HW: 3C8 920 970 P
    Component and/or Version: KOMBI H20 0420
    Software Coding: 440F00
    Work Shop Code: WSC 05314 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 (VW46)
    VCID: 3979CB6FB8AC49D693D-806C
    1 Fault Found:
    12658432 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 178086 km
    Date: 2069.14.17
    Time: 15:27:33
    Tuesday,21,February,2017,17:38:02:62939
    Address 19: CAN Gateway Labels:
    Software Coding:
    Work Shop Code:
    VCID: 55A167DFBCF48DB6975-8000
    3 Faults Found:
    01325 - Control Module for Tire Pressure Monitoring (J502)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 204
    Mileage: 178104 km
    Time Indication: 0
    Date: 2005.14.17
    Time: 17:35:60
    02001 - Data-Bus Automatic Distance Regulation
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 203
    Mileage: 178086 km
    Time Indication: 0
    Date: 2005.14.17
    Time: 15:27:49
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 204
    Mileage: 178104 km
    Time Indication: 0
    Date: 2005.14.17
    Time: 17:35:55
    And in "65- tire pressure - status: cannot be reached 1100" i cant connect (from gateway)
    So plase tell me what a hell it is, and how I can fix it. Big THANKS
    The tpms module has either failed or there is a problem with the wiring.
    Tpms module is behind the rear bumper.
    You need to remove the rear bumper assembly.
    There is a black control module about 10cm long and 3cm in diameter with a single plug attached.
    It's the small black thing with wires coming from it next to the exhaust
    Dec 2012
    Perth, Western Australia
    Umm.... it's not dead batteries in wheel sensors is it? I seem to recall they are fitted on the inside of the rim in the tires.....?
    1981 Honda Civic hatch. Proper AUTO REVERSE cassette player. AM/FM with Stereo speakers. Four (yep, FOUR!) speed manual. Full cloth trim seats. HALOGEN lightbulbs! Factory options fitted: rear wipers and washer, "Go Fast" wheel covers & electric front windows.
    If the wheel sensors are dead or faulty you will still be able to contact the tpms module. Just won't get a reading from the affected wheel sensor.
    Feb 2017
    Suburb
    BIG THANKS for kamold!! Like you sad all problem was for this TPMS module. I change it and now every think is ok. Thanks for your advice and for picture there is TPMS module location P.S. you don`t need to remove all rear bumper, enought to unscrew 3 screws under bumper and you can easy pull out it. Sorry for my pure English
    Great news thanks for reporting back to the forum on the outcome
