I've separated the strut mount / hub assembly from the lower control arm completely by removing the 3 nuts of the ball joint.
The problem is that when I try to flex the hub assembly down, the driveshaft hits on the sway bar.
I am starting to think that the driveshaft needs to be pulled out of the hub?
Sent from my E6653 using Tapatalk
