Results 1 to 4 of 4
Thread: Reverse Camera + Cable harness
    sydney
    Having issues with the reverse camera and boot wont open on pressing the boot badge on Passat 09 cc.
    Boot will open from boot release switch on drivers door panel.
    Found the three broken wires in the boot area where the wiring harness comes out of the inner boot lid tubing .
    Camera comes on with dark background & the steering lines imposed on the RNS510 screen.
    Camera unit / rear badge has not tilted to open position.
    Checked internal wiring harnesses on both sides of boot lid.
    Question 1 how does the boot open when pressing the badge ?
    Question 2 where does the 12v come from to drive the badge / camera motor.
    Any hints
    Mornington Peninsula, VIC
    The release switch in the badge is grounded to the point behind the left boot liner; the other wire goes directly to the CCM (Yellow grey cable at the left connector harness)
    Power for the motor comes from fuse SC17 the ground that completes the circuit comes from the reverse lights.
    It's a common problem with the wiring failing in the hinge.
    Reverse Camera + Cable harness-rvc-guide-jpg
    Reverse Camera + Cable harness-rvc-guide-2-jpg
    MY12 Passat FSI Highline | 3.6L VR6 | Cashmere Brown | Driver Assistance Package | Dynaudio | Discover Media | TPMS Direct | Side Assist | Adaptive Cruise | 3D colour cluster | More coming soon
    Genuine VCDS HEX-NET and VCP Pro
    sydney
    Thanks MIG for the helpful information and diagrams.
    Checked SC17 5 amp fuse located on drivers side dash panel with ohm meter - good
    The original VW manuals refer to fuse 17 for Parking brake / ESP
    Both parking brake & esp are working
    The manual shows orientation of the fuse block 180 degrees to what is found.
    Checked connector in boot well right side single connector T2a ( red yellow ) - 0 volts ( should be 12v , reverse gear and boot closed )
    Disconnected T2a ( red yellow ) and wired 12v onto the camera motor side.
    When placed into reverse gear , camera came up on RNS510 and pressing the rear emblem badge released the boot.
    Getting too dark and tired to trace the red / yellow wire to the fuse block.
    Leave for another day.
    Thanks again for the info
    sydney
    Ok finally traced the red wire with yellow stripe back to fuse block behind the driver side storage box.
    Found the red/yellow wire by chance .
    The wire goes to a 15A fuse located above the top left relay ( 53 ) carrier. Found the fuse to be blown.
    Next to the 15a blue fuse is another yellow 20 A fuse .
    Cannot find in the circuit diagrams the designation / labelling of these two fuses.Reverse Camera + Cable harness-img_20220813_123342777-jpg
