The release switch in the badge is grounded to the point behind the left boot liner; the other wire goes directly to the CCM (Yellow grey cable at the left connector harness)
Power for the motor comes from fuse SC17 the ground that completes the circuit comes from the reverse lights.
It's a common problem with the wiring failing in the hinge.
