Ah, easy - pull back the carpet flap and remove bulb holder (just pulls out) and then just 3 x 16mm nuts. All good! They sure could have made those nuts just a little easier to access though (make the carpet flap a bit bigger) - only had a 3/8" ratchet and 16mm socket. Happy that I got a secondhand lens - can't tell the difference with the others - good match.
The bonus was that the bulb holder in the "new" light was in better nick than mine. These bulb holders seem to overheat and the plastic burns/chars - I believe this is a fairly common problem (?)
