Assistance with brake clunk
So I've been doing some reading and it seems I'm not the only one..
When reversing and applying the brake for the first time after traveling forward I get a very loud and noticeable clunk from the front of the car, both sides. It would seem that the pads are moving around in the caliper.
I have ATE ceramic pads installed (almost 2 years ago) with DBA rotors (closer to 3 years). Is anyone aware of a solution to minimize the movement and noise? Would removing the pads from the calipers and giving them a good clean be a reasonable starting point?
- You may not post replies
- You may not edit your posts
Forum Rules
