Passat CC Window Switches - Where To Source
2009 Passat CC 2.0L TDI.
I need the power window switches (4 switches in the module) for the driver's door - just the module with the four rocker type switches (the side mirror adjustment knob, window lock switch and plastic chassis and wiring are all good). This is what is written on the module in question which I pulled out of the main plastic chassis/frame in the driver's door:
GERMANY 2558 HELAG HLN 3C8 959 857 >PC+ABS-GF10
Waiting on feedback from VW dealer but I've seen these on ebay and alibaba. Does anyone know where to source (don't want second-hand from the wreckers as the plastic rocker switches would likely already be worn) these modules (4 rocker switches) - the chrome front edge wraps around a little and the copies on ebay don't seem to do this. Copy shown below:
- You may not post replies
- You may not edit your posts
Forum Rules
