Results 1 to 4 of 4
Thread: Passat CC V6 Fuel leak
    sydney
    Angry Passat CC V6 Fuel leak
    Just picked up a 2009 V6 CC with 70000kms and filled it with 98 RON.
    Within 5 mins of leaving the servo , I could smell petrol inside the cabin with windows closed , vented the cabin by opening up all windows no better.
    Ended up parking the car in the garage , 30 mins later garage stunk of petrol
    Found a large puddle underneath the fuel tank , fule seems to be leaking from the top area of the fuel tank on the rear passenger side.
    Can't see anything clearly .
    What should I be looking for ?
    Is this thing safe to drive or shall I get it towed back to the dealer .
    Only had the car for 4 hours
    Any advice would be great
    May 2007
    Call roadside assist...
    Then get onto the nearest dealer asap!
    sydney
    Repair update
    Quote Originally Posted by ope126 View Post
    Finally the car dealer workshop looked at the problem.
    Found the sealing gasket ( I assume its a o ring type ) around the fuel pump was deteriorated.
    Car is only 3 years old .
    Access to this area is via removing the rear passenger seat.
    Gasket was replaced and hopefully no more leaks
    May 2007
    Quote Originally Posted by leep35 View Post
    Or just maybe the fuel pump had already been replaced pre-purchase and they did not install properly...
    Glad it's ok now though!
