Call roadside assist...
Then get onto the nearest dealer asap!
Just picked up a 2009 V6 CC with 70000kms and filled it with 98 RON.
Within 5 mins of leaving the servo , I could smell petrol inside the cabin with windows closed , vented the cabin by opening up all windows no better.
Ended up parking the car in the garage , 30 mins later garage stunk of petrol
Found a large puddle underneath the fuel tank , fule seems to be leaking from the top area of the fuel tank on the rear passenger side.
Can't see anything clearly .
What should I be looking for ?
Is this thing safe to drive or shall I get it towed back to the dealer .
Only had the car for 4 hours
Any advice would be great
Finally the car dealer workshop looked at the problem.
Found the sealing gasket ( I assume its a o ring type ) around the fuel pump was deteriorated.
Car is only 3 years old .
Access to this area is via removing the rear passenger seat.
Gasket was replaced and hopefully no more leaks![]()
