Originally Posted by
Highlander
Anyone aware of the acceptable operating range please
Yep, mine (MY10) also has oil temp.
As for operating range, shouldn't worry below 110-115 deg as oil can handle higher temperatures. If during track use it rises higher then it's time to start looking for an oil cooler. I do same as Rocket, don't push hard until oil is in vincinity of 90deg. Once oil is up to operating temp all engine components have reached their operating tolerances (as designed), which they don't when the coolant temp reaches 90deg!!
For the people that don't have the read-out, you can buy strips that you can stick to the sump that record the highest temp reached. It's not ideal, but if you do go on a track then at least it's something to measure what the temp has been. Better then nothing I guess...
R36 Wagon, blue, sunroof, towbar, auto tailgate, MDI, and now with upgraded sound system
1969 TL1600 Fastback
Suzuki GSX1400, Yamaha XVS1100 Bobber
....fairings are for scooters!
