Have noted that one of the displays on the MFD in my CC TDI is oil temperature. Seems to sit around 104 C
May have missed it but can't find anything in the manuals relating to operating temperature.
Anyone aware of the acceptable operating range please
You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
I wouldn't worry about oil being around 104 degrees, it's exposed to more of the workings of the engine than the coolant, and coolant runs around 90-odd.
My car has sat rigidly on 90, even on the hot days in Brisbane lately with the AC running flat out, the car fully loaded, and bouncing around the hills in the west..
MY08 Passat 2.0 TDI Wagon
Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
That's because VW have a little software tweak that forces the gauge to read 90C even when it is a little above or below (supposedly to stop owners freaking out if they see it move even a little bit).
Personally I would rather see it move slightly as the thermostat opens and closes, that way I can see everything is working exactly like it should.
[QUOTE=gregozedobe;418021]That's because VW have a little software tweak that forces the gauge to read 90C even when it is a little above or below (supposedly to stop owners freaking out if they see it move even a little bit).
QUOTE]
LOL - didn't know that. I guess it says something about VW or VW owners in gereral, but I dont know which..... Likewise, I would prefer to see it display the real temperature. (Now someone's gonna chip in and tell us there is a VAG.COM tweak for this)
The oil doesn't warm up as quickly as the water. I wait until the oil reaches around 80 degrees before revving the car.
You can see the oil temp on the MFI.
As an example of oil warming up. It takes 6 km of driving before the oil reaches 80 degrees. The water will read 90 in about 3 km.
