My CC is MY10 with white MFD. Great to have a gauge and no real indication of what oil temperature range is acceptable. I wonder if there is an idiot light/icon that comes on somewhere if the temp is too high. So far haven't found it in the documentation. Also, for sake of curiousity, would be interested to know if NA and TDIs operate at same or different oil temperatures.
You know you are getting old when you cancel your order for a 3.6 CC and buy an Icelandic Gray TDI CC instead.
Strange thing to do.. I'd personally prefer it to wobble, although I do recall that VN Commodores used to sit on cold for normal temperature and only go up if they were working hard.
I've also driven quite a few diseasals, ranging from my brother's 307 wagon, to my old man's previous Merc C210CDI, to 14-tonne trucks (Isuzu, Hino, Mazda, to name a few brands), and one thing they've all had in common is that, once warm, the temperature gauge on them all has stayed in one place - even powering uphill in low range next to raging bushfires on 40+ degree days hasn't moved the needle.
MY08 Passat 2.0 TDI Wagon
Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
+1
my old Vectra used to get up to 100 on very hot days and run very cool at about 80-85 on very cold nights. Subaru must do the same tweak like VW on their temp gauges as well becase my old WRX would never ever fluctuate with water temp regardless of whether you were cruising down a street at 60km/h or belting it around a racetrack.
Pete
MY13 Octavia vRS TDI DSG
Highlander, don't forget 2.0T FSI engines also...
The Oil Temp on mine this morning was displaying a maximum of 95 degrees after 20mins of driving from cold.
The outside air temp was 25.5 degrees.
Interesting, when the water temp reached 90 degrees (and stays there) the oil temp was still only 41 degrees. This was after about 5mins driving.
Will check again this afternoon when the outside temp is into the 30's+...
Had a look this morning - no oil temp on the MFD on the R36.
