Results 1 to 3 of 3
Thread: Number Plate Light
    Jul 2010
    bracken ridge qld
    Number Plate Light
    hi
    i have one of my number plate lights blown and need to replace it.is there anything special i need to get so as not to get a code/cel?
    cheers
    warrick
    2011 3CC 3.6 V6. 19X8 CADWELL RIMS, K & N FILTER, EXHAUST TIPS,DBA SLOTTED FRONT DISCS,ATE CERAMIC FRONT PADS.
    Nov 2009
    These should do the trick:
    â–º Original VW LED 1K8943021 Volkswagen 1K8943021C Golf Scirocco Amarok Passat | eBay
    And you'll need these adapters to handle the current drop and prevent the bulb-out code:
    Volkswagen â–º Plug Play Canbus Adapter â–º VW LED Kennzeichenbeleuchtung â–º Can Bus | eBay
    These are fine for the Golf and Passat 3C, but best to take a look at your CC and confirm they're the same physical size and shape. My father has a CC so I'd check for you, but he's in NSW and I won't be visiting for a while. You could also message carsystems.pl (eBay seller) to confirm fitment and compatibility.
    Jul 2010
    bracken ridge qld
    thanks for that
    cheers
    warrick
